My 93 is an automatic with 320000KM and my 94 is a manual with 285000KM there both tuff. The automatic would be good enough for a light trailer. Just be shure that is has good oil in it, you might want to do a flush (the oil cooler is intergrated into the radiator core), and change the filter. Keep the radiator clean. Try not to rev it at high speed for extended period of time, it will overheat especially in hot conditions and high loads. Its pretty much bullitproof, I've never towed anything with the automatic but I beat the **** out of it. Keep in mind you'll gain a gear with the manual, but you'll lose a torq converter. As far as clutch wear goes the stock clutch is pretty soft, it heats up quick especially when dumping it, and when hot wears rapidly, but as long as you drive normal and dont attamp't any brakestands, and match your rpms well it lasts a long time and is very forgiving.
