idling problem
It seems the fuel injector is pulsating and that is what makes the engine idle up and down. When I put my hand over the throttle body the engine idles below a 1000rpm and runs smooth. Have checked EGR, replace the oxygen sensor, replaced PCV, pulled map sensor vacuum hose and engine runs rich. Check all vacuum hoses and sprayed for vacuum leads, but to no avail. Have recently replaced new fuel pump, fuel filter and relay. And have just replaced the computer. I still am not able to pull codes and check engine light is still on.
