1997 Sidekick sport 1.8l 5 sp. Lower pasenger side ball joint is bad. Ordered a new one and it came as a bolt in ball joint. So my question does the lower ball joint press in to the lower control arm or must I toss the $$$ ( with bushings about 400.00 in parts alone!) and order the complete lower control arm assembly as the dealer says???? or are there any other options for me? Has anyone out there done this replacement???? does anyone know if you can swap lower control arms with another model that has bolt in ball joints?? Has anyone ever machined the lower control arm to accept the bolt in ball joint?? Could this be done? Would certainly appreciate some responses on this. Thanks to all
