umm let me get this straight you were driving and the radio went crazy and then what exactly did the tach do? did it start bouncing? did it spike? or did it drop rapidly? those are some important things, Also the click from the solenoid would probably tell me that its a dead battery, but it could be other things check the connections, good trick to check connections is turn on the headlights and if they turn on connections fine, if they are off and you wiggle the connectios and they turn on its the connections. Now for the loss of power part what exactly happened? did it stall? any leaking fluids? i mean more details would be nice
