why is everyone freaking out over a heavily covered up preproduction car? First off, that lower grills is only going to be on the preproduction car, I would be shocked if they would stop using the mesh grille on the lower half. the roof line and ground clearance you knew would be raised from the concepts, and the headlights don't look as edgy because they're covered up. I'm sure if you peeled back some of that camo around the headlights you would see a sharp headlight design, probably almost identical to the concepts.
