I've got a seemingly simple issue... as, I've been removing a catastrophe of wiring from my Sammi. However, now... I seem to have demo'd something I shoudn't have. Meaning, the previous owner... had an oddball power or ground that I removed.
... everything else works, (instrument cluster) dash lights and everything that needs to be. However, the instrument clusters fuel and temp gauges aren't registering temp... or that there's fuel in the tank and the idiot lights don't come on when you turn the key to "on". They did BEFORE I was carefully removing and re-taping the engine bay and under the hood.
DOES ANYONE HAVE, or KNOW... the wiring color for the instrument cluster? Or if there's a hint of a power or ground that I don't have, but need. There's lots of abandoned wiring under the dash (that I've not touched) with connectors on them, and nothing to plug them into. Some of them even have a "loop wire" in the plug where it's a male spade to male spade bridging two wires. (this is a Samurai with an upgraded engine to a Geo Tracker motor/tranny).
I know this is something simple, but before I waste another hour or two looking for a missing wire/connector... I thought I'd ask here first.
