Upgrading 1.3L Engine VS Swapping to G16A 8V Engine - Suzuki Forums: Suzuki Forum Site
Old 02-20-2010, 11:59 PM   #1 (permalink)
alternator's Avatar
Gallery: 4
Default Upgrading 1.3L Engine VS Swapping to G16A 8V Engine
I've been debating to myself whether to swap to a 1.6L engine or just upgrade my current 1.3L engine. Cost is not an issue, since both will cost me nearly the same. My hesitation is due to the nature of our terrain here. We have mostly sand dunes, and unlike in rocky terrain, if you want to climb a steep sand dune you need to be able to rev very high, right below the redline, and hold it there as long as possible. So I need the high-RPM, and I recall Billjohn saying that the 1.6L engine does not rev as high as the 1.3L engine.
I have taken my Zuk last weekend to the sand dunes near the beach here and I was amazed at the performance I got from the Vitara R/Ps. The car was able to climb the steep hill all the way to the top and all spectators were really impressed; they seriously thought I had swapped the engine with some V6. And I still haven't got the headers and cat back on. I need to drive the engine to 6000 RPM to do that, though, and I'm not sure I will be able to do it with the 1.6L engine.
Any comments? Suggestions?
Old 02-21-2010, 10:33 AM   #2 (permalink)
the reason you need it pegged, is because that is where the peak hp is. The 1.6 will hit that same HP at a much lower RPM and climb to an even higher HP as you tach it up. If you have the time and money for the swap then I would do it.
The 1.3 can be made to go just about anywhere, but it will have to be abused a lot more than the 1.6 to get there.
Old 02-21-2010, 11:42 AM   #3 (permalink)
BESherman is on a distinguished road
In think Baratacus is right on.
In addition, the 1.6 will be superior in every other type of driving condition and will likely last longer than your 1.3.
For the same money, I don't think it's even close.
Bruce
BESherman is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 02:28 AM   #4 (permalink)
wats the difference in fuel economy?
Old 02-22-2010, 03:53 AM   #5 (permalink)
Your fuel economy is going to be where the torque peaks at and how far over that you run your RPM's. The horsepower (69 BHP @6000 rpm) peaks higher than torque (76 ft-lb @3500 RPM) , so running your engine up to 6K RPM's to maximise your HP, you will be burning your fuel ineficiently. If you typically run your engine right around the torque peak then you will have an equally efficient engine compared to the 1.6 running at or below it's torque peak. I generally have to run my 1.3 at high RPM's to keep my power up though. Thus, I end up burning a lot more fuel that I would if I were running a more powerfull motor that didn't require me to rev it that far past it's torque peak.
Old 02-22-2010, 02:11 PM   #6 (permalink)
alternator's Avatar
Gallery: 4
Thanks Baratacus, I get your point. I'm not sure, cuz I haven't tried it, but from my experience in driving in sand, the revving will decipate gradually until you lose the optimal revs at which you get the maximum torque you need and halt. So I would need it to stay up there as long as possible, and I'm not sure the 1.6 will be able to hold it longer than the 1.3.
Bruce
Thanks Bruce.
I'm looking to see the input of Billjohn, since he has done the 1.3 upgrade and is getting a significant gain in power.
Old 02-22-2010, 04:38 PM   #7 (permalink)
The 1.6 will reach the 1.3's max HP at around 4K rpm. it will climb to 50% over the 1.3's rpm by the time it gets to 6K rpm. In many conditions where your 1.3 will start to bog down and drop it's power, the 1.6 will be going strong and not be dropping the revs down. For you to have the 1.6 at an angle or under enough load to bog it down your 1.3L would have already failed. A 1.3 can be built to have the HP that a stock 1.6 has, but it's hard on the engine. With an aggresive cut cam, headders, quad carbs, forged rods and crank, new bearings, an MSD ignition, you're looking at the same cost of a 1.6 swap.
Old 02-22-2010, 04:45 PM   #8 (permalink)
Hot rodding the 1.3 can get you higher output, higher revs, and it will definately get you up that dune. But at a price.
As said in other threads, hopping it up will shorten the lifespan of the motor.
Think of it as a mouse on drugs. He can make that wheel he runs on definately go fast for a longer burst of speed, but it will eventually kill the mouse.
I found that the Stalker is great for racing, but it is not something you use as a daily driver or you will kill it. ( I did twice).
(hot rodding = decked head and block, flat top pistons, radical cam, all new guts and bearings, HD CV carb, header, stock ignition = double the stock HP...)
The 1.6, on the other hand, is a stronger motor than the stock 1.3 and will last you longer.
Does that make sense?
Old 02-22-2010, 10:28 PM   #9 (permalink)
alternator's Avatar
Gallery: 4
Thanks guys, makes perfect sense. Thanks a lot for the advice.
Question: Where is the red line in the 1.6L engine? And will the RPM gauge after the swap give a correct reading?
Old 02-23-2010, 07:17 AM   #10 (permalink)
Guest
Redline is at 6550 rpm.
The 1.6 makes a big difference in power but you won't want to run the 1.3 carb on it, its too small to make max. power on the 1.3 engine, running a freeflow exhaust and a Weber works well.
You should consider running the 16V 1.6 engine instead, the wiring is more complex but it makes the same bottom end power and pulls much harder at higher RPM.
The 1.6 engine isn't much heavier but the bottom end is much stronger with bigger bearings and beefier rods.
