Originally Posted by chevy4x48586
I plan to do the two tracker front 3rd's swap. I've done my research but i was wondering if anyone has done the swap, and what problems if any that they ran into. I've heard about maybe needing to use the sami side gears but as far as i know it should be a direct bolt in swap with 2 front tracker 3rd's.
It is a direct bolt-in, aside from the 26 spline sidegears you need out back.
But remember that the Track/Kick diff housings are aluminum. If you will be going offroad over any rocks or logs (anything hard) you run the risk of cracking the diff like an eggshell. I have heard of no problems in the sand, but don't let them 'whack' anything...
