Old 10-16-2009, 12:55 PM   #1 (permalink)
russellw7272's Avatar
russellw7272 is on a distinguished road
Question Backup sensor and 5th gear sensor
Does anyone know if the backup switch and the 5th gear switch are the same switch? i.e. can I use the same switch in both locations.
Both of the switches have the wires missing and I wanted to replace the switches. I can find places on the internet to buy the backup switch but can't seem to find information on the 5th gear switch. Do you think the 5th gear switch is even necessary? I believe it links to the carb to improve full consumption.
Thank you for your help.
russellw7272 is offline   Reply With Quote
Old 10-16-2009, 03:43 PM   #2 (permalink)
eptali's Avatar
eptali is on a distinguished road
thats interesting. I wasnt aware of the 5th gear sensor. Whats the use of that, locks out reverse??
eptali is offline   Reply With Quote
Old 10-16-2009, 05:22 PM   #3 (permalink)
Ya it sits behind the backup sensor. I read that it "tells" the carburetor that you are in 5th gear and it helps to improve fuel consumption!! Not sure about this though!!
Old 10-16-2009, 05:32 PM   #4 (permalink)
87samurai_dunn is on a distinguished road
both switches should be the same... just make sure they are wired to the correct place
87samurai_dunn is offline   Reply With Quote
Old 10-16-2009, 10:16 PM   #5 (permalink)
thanks!! I have found the old wires so will make sure I connect them properly. Thanks for the help!!
Old 10-19-2009, 06:54 PM   #6 (permalink)
ack
Default transmission switches
Note that the plugs are different on those two switches. One is male and the other is female.
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
'88 Samurai Offroader
'02 Tracker ZR2 4-door Daily Driver
ack is online now   Reply With Quote
Old 10-20-2009, 01:00 PM   #7 (permalink)
Great thanks, that will help knowing which wires go to which switch!!
Old 10-20-2009, 03:35 PM   #8 (permalink)
but if the wiring is all messed up the connecters dont matter...the switch itself is the same with a different connecter on the end... you can put whatever kind of connecter you want on them or just wire them strait
Old 10-20-2009, 04:16 PM   #9 (permalink)
Ok great. Thanks everyone for their help!!
