Many thanks for the help Billjohn.
I looked at the rearsprings again and the shape is slightly curved (smiley) except for the middle where it curves in the opposite direction... a sort of moustache shape.
The front does look higher than the rear but this might be because the rear springs are stuffed. Theres about 80mm (3") between the rubber bumpstop and the front axle housing. I read in a recent post that this distance should be about 1" on with the standard suspension. If that is the case then it suggests to me that the suspension is in fact 2" (50mm) higher.
The problem is that because I live out in the country i have to order them (springs) in and Im worried that Ill get the wrong ones. Which would be a major pain in the proverbial place
cheers charlie
