Suzuki Samurai Lift??? - Suzuki Forums: Suzuki Forum Site
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read
Old 08-06-2009, 06:37 PM   #1 (permalink)
Roody is on a distinguished road
Default Suzuki Samurai Lift???
I have just purchased my first suzuki samurai. it is a 1987 samurai tin top. i was just wondering what upgrades are available. i am somewhat handy with a welder and metal work and i was wondering if anybody had any tips, or plans for building my own lift for my samurai. heres a pic-
Roody is offline   Reply With Quote
Old 08-06-2009, 09:50 PM   #2 (permalink)
87samurai_dunn is on a distinguished road
i have an 87 also and for now i started with a 2 inch shackle reverse kit from calmini with rancho shocks and that was about $400 bucks, then i did 3 inch hoops on the front for more articulation and a softer ride, now im working on 3 inch lift springs but im going to have to get the drop steering arm and extended brake lines but the shackle reverse kit is an exelent start, if ur happy with articulation and ride then u can go spoa (spring over axel) and that will give you an immediate about 4 inches of lift but you have to get the drop steering arm and brake lines for that too. i also highly recomend a 2 inch body lift, i smashed my front end in a ditch and if i had the body lift it would have never happend but just keep in mind that a quick lift turns into a lot with steering, brakes, shocks...it all gets expensive fast
87samurai_dunn is offline   Reply With Quote
Old 08-07-2009, 02:17 AM   #3 (permalink)
alternator's Avatar
Gallery: 4
Personally I don't think the skackle reverse kit is a good idea. It causes break dive, and reduces your approach angle.
Best way to go is SPOA. I also recently bought my 91 Samurai, and I did a paint job and now I'm installing a SPOA weld-on kit from rocky road outfitters. I trust they have one of the best SPOA kits around. But don't go for the cheap type with the perches welded on the axle housing, I suggest going for the higher quality perches that weld on the OE spring perches. That way you will eliminate the stress occurring on the sort-of weak axle housing.
I'm right now working on installing the SPOA kit. Here's a picture of my Sammy before the SPOA, after I completed the paint job.
Suzuki Samurai Lift???-dscn3212-2-.jpg   Suzuki Samurai Lift???-dscn3213-2-.jpg
alternator is offline   Reply With Quote
Old 08-07-2009, 12:07 PM   #4 (permalink)
looks great. and how much was the spoa kit that you buoght? and where could i order one? also is there maybe anything i can fabricate myself?
Old 08-07-2009, 12:45 PM   #5 (permalink)
alternator's Avatar
Gallery: 4
Yes you can fabricate it, but why re-invent the wheel? A lot of designs have emerged over the years, and they have learned from various mistakes, and incorporated the fixes in the final products. It will save you a great amount of time buying ready spring perches; and you will have to buy drive shaft spacers and break line extenders any way. The weld-on perches don't add a great deal of cost to those; in fact, they're quite inexpensive.
You can find them at different places, such as low range off-road, spidertrax, or rock road outfitters. I got mine from rocky road.
A basic SPOA lift can cost very little, will contain spring perches, drive shaft extenders, and replacement break lines only, and costs pretty low. Low range offers this basic kit for only $199 and a Z-link steering bar for $95, which is a must. This will give you 5" of lift. But you can't get much articulation from that, because the stock shocks are short and stock springs are inflexible.
Or you can go for the fully fledged SPOA conversion like the one I got, which cost me about $1100. That includes shocks, springs, upper rear shock mounts, lower front and rear shock mounts, and Over the Top (OTT) (TM) stage one steering system.
To have a complete job, you (and I) should also get stage 2 OTT steering, upper front shock mounts, traction bar on the rear to eliminate axle wrap, panhard bar on the front to eliminate vibration, or even missing link shackles for ultimate articulation.
In my opinion the easiest way to get a decent and safe 4" lift is by simply replacing the springs with 2" lifting springs such as ARB's OME Dakar springs, and install 2" lifting shackles. This is very easy, but will not cost much less.
Old 08-07-2009, 05:29 PM   #6 (permalink)
I agree with many of your points, but this one just needs a little more explanation.
The springs are a good choice, as are the shackles, but that still leaves the brake lines, driveshaft length, shocks and steering to be dealt with.
With 4" of lift you can't use stock steering, the wheel won't center and you will have problems turning right (drag link won't have the reach). And going cheap with a 'Z' link steering bar will allow the additinal length but will increase bumpsteer. Go highsteer.
You will still have to get the driveshaft spacers longer shocks and brake line extensions.
Unfortunately, a 'simple' lift (if more than 2") is not really very simple (if you want to be safe).
Old 08-08-2009, 01:07 AM   #7 (permalink)
alternator's Avatar
Gallery: 4
Hay Bill, you're the expert here. I'm only talking from theory, you're talking from practice.
I read in Rocky Road website that up to 3.5 inches (or was it 4? can't remember) of lift don't require changing anything in the steering, break lines, or drive shaft. One thing for sure, the OME springs (without the lifting shackles) definitely don't require any modifications on those parts.
Old 08-08-2009, 01:24 PM   #8 (permalink)
When sitting still (or even with light articulation) the brake lines will be fine, but with the articulation that is possible with this lift it will stress the lines to the point where they could fail. I explained the steering problems that will come up.
The springs alone should not cause much of a problem, but understand that stock shocks will limit down travel. But on the good side, the shorter shocks can save the brake lines...
Unfortunately, when we start to upgrade our zooks, we continue to find more things that can use upgrading.
Old 08-08-2009, 01:35 PM   #9 (permalink)
alternator's Avatar
Gallery: 4
LOL you're absolutely right
You do that, then you realize that you need to do this as well to fully benefit. Then that then this, and the list goes on.
When I first bought the Zuk, I was thinking of a moderate lift using OME and lifting shackles, then I thought of just getting a basic SPOA. Then decided to add to it the springs. Then decided to change the shocks as well. Then decided to go for the OTT steering instead of the Z-link. And in the end I ended up with a long list of new parts.
Old 08-08-2009, 07:50 PM   #10 (permalink)
well i pick my samurai up tomorrow. and come monday i'm gonna take it in to be pre saftied. if i can get it on the road i prolly wont lift it, and if i do it wont be much over 2". and if i cant get it on the road i will want to lift it atleast 5". so is there any lifts out there that will lift my samurai 2"? and for driving it on the road is it safe to lift it? i've herd that samurais in the first place aren't the best for staying on all four tires. so is a lift a bad idea if i'm puting it on the road?
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
