They do get a bit sloppy over the years. A certain amount is nothing worry about.
1. Oil seal
2. Bearing
3. Carrier
4. Joint flange
5. Bearing preload
adjusting spacer
6. Shim
7. Bearing
8. Bearing adjuster
9. Side bearing
10. Adjuster lock plate
11. Bevel gear pinion set
12. Bolt
13. Rear axle housing
14. Front axle housing
15. Bolt
16. Oil level plug
17. Gasket
18. Oil drain plug
19. Right case
20. Thrust washer
21. Joint
22. Thrust washer
23. Pinion shaft No. 2
24. Pinion shaft No. 1
25. Side gear set
26. Left case
1989 LWB Custom body Samurai with 1991 MPFI 16valve Vitara engine, 1994 SWB Samurai, Calmini Shackel Reverse, lift springs, 31x10.5x15 Khumo LR71s. 1986 Santana std. 1988 Samurai Std.
