Originally Posted by Billjohn
Bingo!
But when you install a locker, the locker discs replace the spider gears. The discs sit directly over the pins. Think of the pins as the rebar in a cement pad. The more rebar, the stronger the pad.
I'm trying to imagine how the locker will fit, because I am planning on getting one, and my Samurai is 91 year model. So according to you, it has only two pins (One actually). Spidertrax lockers have the option of getting 26 spline side gears, or without them, if yours are ok. So how will the locker discs interface with the stock side gears? And is it possible to drill a couple of holes and install the other two pins?
I'm planning to opt for the one without side gears, because I don't want to change my 22 spline axles. What do you suggest?
