Old 06-24-2009, 10:12 PM   #1 (permalink)
VIRGOPELO is on a distinguished road
Default Help Me With The Engine
Hi to all i have the following problem with my engine ,in neutral i an able to accelerate until 5500 rpm but when is engage in any speed after 2 gear it won be able to go over 3000 rpm,so the problem is when the engine have a load
any idea
thanks
VIRGOPELO is offline   Reply With Quote
Old 06-25-2009, 03:05 AM   #2 (permalink)
munyuk4x4 is on a distinguished road
Sounds like the same thing I have. Spoke to mate and he said it sounds like I might need to do a rebuild.
munyuk4x4 is offline   Reply With Quote
Old 06-25-2009, 07:22 AM   #3 (permalink)
spo3nazgul's Avatar
spo3nazgul is on a distinguished road
well my advive if your going to do a rebuild get a tracker engine or a toyota 4age. if you have money get the chevy vortec v6
spo3nazgul is offline   Reply With Quote
Old 06-25-2009, 08:34 AM   #4 (permalink)
What year, country, engine, transmission? Have you done a compression or leakdown test? If you have a ECM, do you have any codes stored?
Old 06-26-2009, 02:55 AM   #5 (permalink)
I am in Australia its a 96 manual transmission 4 cylinder 1.3lt jx
Old 06-26-2009, 06:28 AM   #6 (permalink)
Again, have you done a compression or leakdown test? If you have a ECM, do you have any codes stored?
Old 06-26-2009, 08:24 AM   #7 (permalink)
Hi I An In Miami Fl And Is A 1987 Carburetor G13 1.3l ,this Is A Not Smoking Engine So I Believe That The Compression Is Ok , The Carburetor Is The Hitachi ,
Will You Consider That The Ignition Coil Culd Cause This Problem ?
