You need to check the handbook to see what the minimum recommended octane rating is, its probably 92-94 octane RON. If you have a G13BB engine then there is no knock sensor and the ignition timing is fixed so there are no benefits to be gained from running a higher octane fuel. If you have the M13 engine then you may have a knock sensor which means that the ECU can adapt to run more efficiently on a higher octane fuel.
