Old 05-30-2009, 03:37 PM   #1 (permalink)
hooperdoski is on a distinguished road
Default Ignition Switch Problem
I have an 86 Samurai. I'm having a problem with the ignition switch sticking in the start position. I think I need to remove the portion of the switch that turns when you turn the key. Once that is done I think it's just a matter of cleaning it. Does anyone know how to remove the key cylinder of the ignition switch?
Thanks in advance.
hooperdoski is offline   Reply With Quote
Old 06-01-2009, 12:27 AM   #2 (permalink)
You may be able to free up the sticking lock cylinder without removing it. I'd start by trying a liquid graphite product called "Lock-Ease", available at NAPA and Ace hardware, among others. It's in a blue and white can. It's graphite in a petroleum solvent suspension, which evaporates, leaving the graphite behind.
I first used it in Africa, 41 years ago, to flush out and lubricate motorcycle throttle and brake cables. I wouldn't be without it.
Merlin93 is offline   Reply With Quote
Old 06-01-2009, 09:38 AM   #3 (permalink)
Good idea. Haven't heard of the stuff, but will look for it. However, I thought about using a liquid base lubricant, but I tried to fix the problem using powered graphite and now I'm afraid any liquid based lubricant will cause the powered graphite to gum up making matters worse.
I'm surprised I haven't heard from someone on removing the key cylinder from the switch. In most cars it's easy to do. Surely someone knows how to do it.
Thanks for your reply.
Old 06-13-2009, 12:19 PM   #4 (permalink)
Default Still need info on key barrel removal
Still hoping someone can help me on removing the ignition switch cylinder removal. I need to get the barrel out that holds the tumblers.
