Old 04-30-2009, 12:52 PM   #1 (permalink)
Phils is on a distinguished road
Default Shifter sheets?
How easy is it to change the transmission "shifter sheet"?
Can anyone post a link to some installation instructions or give me some tips? I haven't been able to find them online.
I received my new transfer case "shifter sheet" yesterday. When I first bought the Zuki, it only took me a day or two to lock up the transfer case. I took the shifter out, repositioned the rods, reinstalled and it's been fine since because we leave it in 4wd-LO .... until my neighbor, convinced that we were in 4wd-HI and not LO, moved the x-case shift lever and locked it up again. So I pulled it apart, repositioned, reinstalled again. There has never been so much as a remnant of the original so I didn't realize at first anything was missing. I'm confident I can have the new "shifter sheet" (what an odd nomenclature) installed in a few minutes.
But the transmission is just as sloppy and the 'sheet' is almost as inexpensive as the one for the xfer case.
Is it as easy to change? Take off the boots, push and twist a lock, pull the shifter out, put a 'sheet' in, put it back together? If it's very complicated, we can live with it as it is but if it's as easy as the xfer case, I'll put a new 'sheet' in.
Phil
Phils is offline   Reply With Quote
Old 05-01-2009, 02:21 AM   #2 (permalink)
hotrodsami's Avatar
yes the transmission sheet is just as easy as the transfer case. but if your tansmission is sloppy there is a bolt in the shifter that might need replaced to. the bolt is easy to get to and cheaper than the t-case sheet.
this web site has the t-case sheet and a kit to fix your transmission
Suzuki transfer axle gear kits
and this web site shows the install for the t-case sheet
RRO Shifter Sheet - Trucks 4x4 @ Off-Road.com
hope this helps
Failure is always an option
Last edited by hotrodsami : 05-01-2009 at 02:22 AM. Reason: forgot to put a link in
hotrodsami is offline   Reply With Quote
Old 05-01-2009, 01:27 PM   #3 (permalink)
Thanks hotrodsami.
I was wanting to make sure the fix for the transmission wasn't very involved either. I appreciate the links.
Phil
Old 05-11-2009, 02:05 PM   #4 (permalink)
There are also "25-year" parts for both in brass from Myron at ZuksOffRoad (ZOR).
ZuksOffRoad
The early Zuks had a small 8mm shifter locator bolt, which often breaks (be SURE to remove the broken tip). Later (88.5+) Samurais had a larger 10mm bolt which doesn't break. Hawk sells an upgrade kit, 'cause you have to change out (re-machine) the shifter and shift tower to accept the larger bolt. It's currently on the specials page at HAWK STRICTLY SUZUKI
Merlin93 is offline   Reply With Quote
Old 05-11-2009, 02:13 PM   #5 (permalink)
Thanks for that info Merlin.
I might have considered the "upgrade" but it's a done deal now. I put the new bolt and sheet in last Friday.
And the bolt tip WAS indeed broken off, and I couldn't retrieve the broken piece. I took off the part the bolt goes into, looked long and hard, but never found the missing chunk.
All I can do at this point is hope it fell to the bottom of the tranny and won't get caught in the gears.
Phil
Old 05-12-2009, 12:45 AM   #6 (permalink)
Originally Posted by Phils View Post
...And the bolt tip WAS indeed broken off, and I couldn't retrieve the broken piece. I ... looked long and hard, but never found the missing chunk. All I can do at this point is hope it fell to the bottom of the tranny and won't get caught in the gears. Phil
You may be able to fish or flush it out through the drain plug. If it bounces around and gets caught in the gear teeth, you'll have a lot more (expensive) work to do. Some kind of magnetic device attached to the drain plug might hold it until you get it out. Perhaps a rare-earth (neodymium-iron) disk magnet could be epoxied to the drain plug. I see the disks at the swap meet for a buck or two.
Old 05-12-2009, 12:04 PM   #7 (permalink)
Good idea on the magnet Merlin. I'll start planning on that, first finding a suitable magnet.
Phil
Old 05-12-2009, 12:16 PM   #8 (permalink)
hotrodsami's Avatar
most transmission drain plugs are magnetic from the factory but it's never all that strong a magnet. go a head and pull it out and see if you find it(or can flush it out) but if you don't have any luck get a stronger magnet and try it.
good luck
