Old 03-16-2009, 06:52 AM   #1 (permalink)
reida_1991 is on a distinguished road
Default Dangerous Sierra
Hello again,
My 1.3L sierra has developed a problem that appears to be getting worse.
Going around tightish corners the engine sort of jumps and jerks, power dies. I look like an idiot and it sometimes occurs when taking off at intersections, not in the least convenient in a tight spot. What could be causing this? I'm running premium fuel 96ron and stock 1.3L.
Any thoughts much appreciated.
Reida
reida_1991 is offline   Reply With Quote
Old 03-22-2009, 09:46 AM   #2 (permalink)
spo3nazgul's Avatar
spo3nazgul is on a distinguished road
sir i think that it might be serious. did you try checking the carb or the air filter?
spo3nazgul is offline   Reply With Quote
Old 03-22-2009, 10:43 AM   #3 (permalink)
mule's Avatar
also check ground connections...just a thought
best of luck
I HATE Consumer Reports
mule is offline   Reply With Quote
Old 03-22-2009, 12:07 PM   #4 (permalink)
Rhinoman's Avatar
Check that the engine and gearbox mountings are good. Then check all wires connected to the engine, particularly the ground connection to the distributor.
Old 03-22-2009, 08:12 PM   #5 (permalink)
squid is on a distinguished road
let me make sure we understand, you only have a engine power issue when you turn sharp corners?
squid is offline   Reply With Quote
Old 03-23-2009, 03:38 AM   #6 (permalink)
Yes, thats why i think its a fuel surge or something. I'm talking about around 90 degree intersections and such. You put your foot into it and you get coughs and splutters as though theres no fuel getting to it. Air filter is fine, and the fuel filter is something I will check.
Cheers
Old 03-23-2009, 03:39 AM   #7 (permalink)
Ok can ask your reasoning? Thanks
Old 03-23-2009, 05:03 AM   #8 (permalink)
Rhinoman's Avatar
If an engine mount is broken then the engine will move around more and can pull on the wiring. The ground lead to the dizzy seems to be the one that gives most problems.
Old 04-04-2009, 02:17 PM   #9 (permalink)
spo3nazgul's Avatar
did you check the distributor cap??
and is it direct injection or carb??
