The ring gear has a larger inside diameter, so the kit comes with a 'can' (cylinder with no top or bottom) that slides over the carrier chunk. This keeps the center pins from sliding out. It also includes a spacer that will move the ring gear a little farther away from the center point. The teeth in the ring gear are a little taller so the spacer lets you adjust without running out of adjustment on the bearing ring adjuster. Sorry, the picture is just a standard install, couldn't find one I did with a conversion kit...
