Originally Posted by Pilsner Pig
If I'm not mistaken it is easy to tell whether or not it is the valve stem seals or the rings based on when it smokes. I think that if it gives a puff of blue when you first start it then it is the valve seals as the oil will run down and sit in the combustion chamber and once you start it you get that puff and once the seals heat up they seal a little better and the smoke will disappear.
If it smokes all the time it is probably the rings. You can do a compression test and further more if you find a weak cylinder do a leak down test by throwing some light weight oil in the weak cylinder and quickly testing the compression again. If it goes up slightly for a short period then you have a leaky set of rings.
As far as getting down to Cali I've had an invite to visit the San Bernadino wildfire crews but haven't found a way to explain to the wife and piglets why daddy is taking a 'zuki road trip to California without them. I just need an actual wildfire incident request and I'll stop on my way through for a brew! Maybe you are having a Mountain Pine Beetle epidemic I can come down and help you deal with....anything to hit the "Dogtown Hotel and Saloon" if they still are open for beer.
Since putting in the STP stuff, the smoke is greatly reduced and it's been raining finally so we haven't been driving the Zuki for a couple of weeks now.
I DO have some beetles killing my "digger pines" (dunno what they are actually called) which is NO BIG DEAL since we consider them "weed trees". No good for shade, no good for firewood either. If they start getting into the Ponderosa pines I'll start crawling up the trees and digging them out.
And I NEVER want to have a summer like last for wildfires! Dogtown Hotel and Saloon isn't around anymore as far as I know. But I can make and hang a sign.
Phil
