Old 02-14-2009, 10:51 PM   #1 (permalink)
lawnmowerracing2 is on a distinguished road
Default samurai fuse problems Please help
hi i have a 1990 samurai with EFI, i have had it for 2 months and it is my daily driver and has been running excelent until yesterday. it blew the 15 amp F I fuse which runs a bunch of things. i put a new one in and it worked for 20 minutes or then blew out again. everything seems to work, radio, lights, starter, but the fuel pump shuts off. so i tried another fuse and blows as soon as the key is turned on. i have tried to check for bare wires and shorts in the wire harness but found nothing. now i am at a stand still and don't have the money to bring it to the dealer . any advice you have would be nice to hear, thanks Jason
lawnmowerracing2 is offline   Reply With Quote
Old 02-15-2009, 10:31 AM   #2 (permalink)
Harleyindahouse is on a distinguished road
1st thought; fuel pump failure (shorted) or you maybe looking at a computer failure.
You can or should be able to hear the fuel pump whirl momentarily when you trun the key on till the fuel pressure is up.
Uncommonly the fuel pump relay can fail but unlikely! It is east to isolate but any problems with fuel pump you are likely going to need a complete fuel pickup assembly with fuel pump because it probably severly rusted.
You could probably do the easiest test if you pull the fuel pump relay and bypass the relay at the four pin plug socket lower left dash... relay should be attached to computer case bracket.
Harleyindahouse is offline   Reply With Quote
Old 02-15-2009, 10:35 AM   #3 (permalink)
btw: if you end up needing a computer I probably have 99% certain!
$120.00 tested working
Old 02-16-2009, 01:02 AM   #4 (permalink)
squid is on a distinguished road
Default blown fuses
this is where the wire diagram would come in handy. one fuse may power several items.
if fuse blows as soon as ignition is turned on , you can unplug things intill it stops and what ever item is unpluged is your suspect.
I use a "short finder" avalable in most part stores. it is a circuit breaker which is put in place of fuse and a small gauge which is placed near the wiring. the needle swings back and forth when it is near the wire that has the short, then the gauge is move down the wire and the needle will stop when short is past .
squid is offline   Reply With Quote
Old 02-16-2009, 03:28 AM   #5 (permalink)
I just looked at diagram; "lawnmower" identifies his problem at fuse # F1(circuit is constant live) connected input (b/r) to main relay. From main relay "load" circuits are (b/w) to stop lamp switch, (bl)main relay to ECM, and (bl/b) main relay to emmision control devices; solenoid purgue valve, EGR sv valve , TCC relay but these (3) all trace back circuits to ECM.
I have a short detector but becuase of the confined spece it is not practical and usually only used for long line circuits.
Find the main relay first; you could in fact only have a problem with a shorted relay but it it the relay near the ECM "4 wires" I would unlug the main relay first and use a jumper wire in place on the connector from black/red to any of the other three terminals one at a time to black/white, then black/red to blue, then black/red to blue/black.... look for the black/red to blue jumper to blow the fuse.... That is the ECM!....
This will isolate which circuit is affecting fuse the most..... but also lower your test fuse value to say 5 amp max for these tests.
Old 02-17-2009, 06:50 PM   #6 (permalink)
thanks for all the information. i unpluged every connector in the wire harness in the sami and turned the key and it didn't blow the fuse, then slowly plugged in the rest one at a time with no blown fuse. then i pluged in the fuel pump and blew it instantly. so i thought it was drawing too many amps so i hooked it up to a spare battery with homemade jumper wires and a 15 amp fuse. i let it run fr about 30 minutes and it didn't blow the fuse. so for now i just ran some 14 gage wire from the pump to the key switch with i 15 amp fuse and it is working great so far. i know it probably isn't the correct way to do it but it works for now. Please let me know what you think about what i did and if it will hurt somehting.
Old 02-17-2009, 09:34 PM   #7 (permalink)
Not good becuase you will likely fry something else; computer will fail shortly most definately!!!!!
Fuel pump relay is mounted on the computer and there is a test for the fuel pump but unfortunately that is a normal occurance. You must remember that you are bypassing all control processing for emissions but if the pump is seizing which is common it will take out the computer.
