Suzuki Jiminy 4x4 making grinding noise only in 2 wheel drive. - Suzuki Forums: Suzuki Forum Site
Old 01-09-2009, 02:29 PM   #1 (permalink)
Brigadore1 is on a distinguished road
Default Suzuki Jiminy 4x4 making grinding noise only in 2 wheel drive.
Hi, my Suzuki Jiminy has started makin a strange grinding noise when in 2 wheel drive, soon as i put it on 4 wheel drive it stops! The noise is intermittent, sometimes does it, and sometimes not, but never makes it in 4 wheel drive mode.. I have had into 4x4 specialists and even the suzuki dealer and they can not find the fault, any help is appreciated !
Brigadore1 is offline   Reply With Quote Quick reply to this message
Old 01-09-2009, 06:04 PM   #2 (permalink)
twiss2k5's Avatar
twiss2k5 is on a distinguished road
dont know about grinding
but have you tried running with the front prop disconnected?
the front output shaft bearing in my Samurai t-case went and made funny noises in 2wd, but not in 4wd because of the tension on the prop when it is engaged. i've had it do the same thing with broken UJs as well but grinding doesnt sound good.
may be worth taking the front prop off and seeing if it makes a difference...?
depending on the main dealers i would've thought they'd check UJs and such
if with the front prop off it still makes the noise i'd look at the front axle, if it stops i'd look at the tcase output and the prop UJs...
also does your jimny have auto locking hubs?
Twiss2k5
'93 Suzuki Samurai Sport 1600
twiss2k5 is offline   Reply With Quote Quick reply to this message
Old 05-29-2009, 07:10 AM   #3 (permalink)
pettrov65 is on a distinguished road
Hi. I have a 2008 Jimny Sierra, Australia, 5 spd manual. It made a noise on acceleration in 3 & 4 gears, 2WD. Eventually fixed by changing 2 gears as a matched pair, and the chain, in the transfer case. Good luck..!
pettrov65 is offline   Reply With Quote Quick reply to this message
Old 05-05-2013, 06:02 PM   #4 (permalink)
Alana29 is on a distinguished road
Hi,
I am encountering the exact problem, changed my differential oil, seals, 4 small bearing on the front wheels and the noise is still there, can you tell me what you did to solve the problem.
Many Thanks
Alana29 is offline   Reply With Quote Quick reply to this message
Old 05-14-2013, 01:21 AM   #5 (permalink)
trevor55 is on a distinguished road
I have a 2006 Jimny with only 100000km. The gear box is shot.Sounds like a cement mixer.The zook has never been off road and driven carefully.Any of you had the same problem?
trevor55 is offline   Reply With Quote Quick reply to this message
