Old 09-16-2008, 03:07 PM   #1 (permalink)
samurai2009 is on a distinguished road
Default samurai questions
I have an 88 samurai. I would like to know if samurai's come stock with a weber carb, because mine has it. also what (cheap or used) leaf springs can i use on the front for a possible lift and also as a needed replacement. thanks
samurai2009 is offline   Reply With Quote
Old 09-16-2008, 06:57 PM   #2 (permalink)
JPR Ram is on a distinguished road
No, Webers are not stock, nor are they Smog legal; if you're state has that kinda stuff. From the factory, Samurai's come with a Hatachi (sp) carb.
JPR Ram is offline   Reply With Quote
Old 09-16-2008, 09:09 PM   #3 (permalink)
You can use rear springs up front (RUF conversion) and a set of front CJ leaf packs in the rear of the Sammy.This is good for about 2" and a smoother ride.
Old 09-16-2008, 11:26 PM   #4 (permalink)
well i think that my leaf springs are (besides broke on the front pass side) worn out to. they sit about flat and i know that they should have some sort of arch to them. could i use cj springs all the way around? please give me some details to this
Old 09-16-2008, 11:41 PM   #5 (permalink)
Going RUF/CJ includes using a drop shackle in the rear and maybe in the front depending on how you do it. But using a CJ spring up front will make the spring stick out way beyond what you want unless you start thinking about 33" tires... here is a shot of that setup with 32's.
and here is how you do it...
Going Long - CJ Spring Packs Up Front
If you stick with zook rears up in front, you would need to lose the overload spring and take the #2 leaf from the front packs and add them into the rear packs. This gives you a little more flex while keeping the strength.
Remember that Samurai springs were designed to start/rest in a flat configuration, not like the arched springs you see on lifted spring suspensions.
Old 09-17-2008, 11:50 PM   #6 (permalink)
whats kinda funny is that i aready have 33's on it. thanks to the cheap shackle lift and a sawzall. so now i found some used stock leaf springs to replace the broken ones and i figured maybe some add-a-leafs all around would lift it.
Old 09-18-2008, 12:18 AM   #7 (permalink)
One word of caution... Lightweight Samurai + add-a-leafs = paintshaker...
Really stiff suspension.
Old 09-18-2008, 11:45 PM   #8 (permalink)
I am going to get my replacement leafs friday, and from what i understand i can basicly combine different leafs to give it back an arch and thus lifting it to. hopefully its works out good. and i also just modified my doors so that they are removable. these's suzuki's are cooler than jeeps
Old 09-19-2008, 12:06 AM   #9 (permalink)
Yup. That is what I did to get a good tight (and lifted) suspension for the 31's. It cornered like it was bolted to the center line.
OME/Stock/CJ front leaf combo
Stance - iZook
Old 09-21-2008, 02:52 PM   #10 (permalink)
mule's Avatar
yes sir, yes they are, welcome to the addiction
mule is offline   Reply With Quote
