99% of temp gauges are electrical, the sender in your manifold is fine for the task (if your dash has a temp gauge that is), just wire up the new temp gauge. If it doesn't, just replace the temp warning sender with a auge sender and away you go.
Rev Counter is just as easy. You will have 3 conns on the back of it (plus illumination of course) Positive, Earth and Coil input. Most should come with instructions anyway, it is all pretty straight forward.
1989 LWB Custom body Samurai with 1991 MPFI 16valve Vitara engine, 1994 SWB Samurai, Calmini Shackel Reverse, lift springs, 31x10.5x15 Khumo LR71s. 1986 Santana std. 1988 Samurai Std.
