Old 06-13-2008, 09:35 PM   #1 (permalink)
madzook is on a distinguished road
Exclamation Gear knob
Does anyone know how to get a gear knob off of a 1995 Suzuki Sierra? MIne just wont budge.
madzook is offline   Reply With Quote
Old 06-14-2008, 12:09 AM   #2 (permalink)
footloose's Avatar
footloose
I had the same problem on my 1985 Sierra. I thought I'd have to cut the gear knob off but I ended up removing the gear stick and putting it in a vice and used a pair of stilsons on the knob to remove it. Now that the gear knob has been off I can remove it by hand without removing the gear stick from the gear box.
1985 Holden Drover Soft Top
Dual Batteries
Extractors & 2" Exhaust
Ported & Polished Head
2" Suspension Lift
75ltr Long Range Fuel Tank
150w Spotties x 2
4 Post Bullbar
footloose is offline   Reply With Quote
Old 06-14-2008, 08:14 AM   #3 (permalink)
the manufacture uses some sort of lock tite. i know in the past i have had to heat bolts on the sami to get things loose. i do not know if this is plausible with the gear shift.
good luck
my .02 cents
mule is offline   Reply With Quote
Old 06-23-2008, 02:09 AM   #4 (permalink)
I managed to get the knob off by removing the whole gear stick and using some pliers, however now i can't get the gear stick to get back into the case??? any ideas
Old 06-29-2008, 01:52 AM   #5 (permalink)
chelerizr's Avatar
chelerizr is on a distinguished road
it's because of the bearings check them and try putting the gear in neutral move it with a flat screwdriver it's easy check the bearings if you don't the stick will move strangely XD
chelerizr is offline   Reply With Quote
Old 06-29-2008, 02:47 AM   #6 (permalink)
Default GEar knob
Chears mate i managed to change the the shifters, it was in 2nd gear.
