What is that SOUND?
When I push in/let out the clutch there is a loud rubbing sound. Very mechanical type of sound, like something binding up. The cluthc works perfectly. I have crawled under the dash as best I can, sprayed every moving part I can see with silicon, white lithium,etc. No better. I did the same under the rig where you turn the adjustment on the cable. I am not any kind of mechanic so I may be missing the obvious. Any ideas? It cannot be a good thing. PG
