I had exactly the same! This was due to a blown head gasket. The water then leaks through to the sump, and with the heat the water evaporates and then condenses into the hose. The reason why everything is spitting out, is because some pressure from the combustion chamber escapes into the sump, and this blows out everything - All thats needed is to take the head off, skim it if necc, do a pressure test and refit with a new head gasket! Hope this helps!
