Originally Posted by michael-toth
ok thanks wat kind of aftermaket shocks and springs should i go
If you are in Australia or New Zealand then I would suggest Old Man Emu (usually available through ARB agents), EFS or even Tough Dog.
You might need to look for Jimny kits as the coil Sammy/Sierra was only in production for a couple of years but talk to your suspension supplier to confirm they will fit your model.
I am personally running a 40mm lift Old Man Emu kit as they are designed to suit the extra weight of the ARB bullbar/winch-bar. Just be careful about going toooooo high with the lift as it will raise the centre of gravity (and change your caster angles which will make the steering super sensitive) which could result in stability issues when driving along banks.
