G'day Juju,
To replace the stripped wheel stud requires removal of the following:
Free wheel hub
Disc rotor
the hub which the wheel studs are attached to
While you have the hub off the axle it's a good time to check the wheel bearings and if they are OK clean and repack them with new grease. If they are on their way out it would be a good idea to do the other side as well. I've just reconditioned my front axle on my 1985 SJ410 Suzi and it took me about 2-3 hours for each side. Now I won't have to do them again for another 10 years. Hope this helps you out.
Cheers form Down Under
1985 Holden Drover Soft Top
Dual Batteries
Extractors & 2" Exhaust
Ported & Polished Head
2" Suspension Lift
75ltr Long Range Fuel Tank
150w Spotties x 2
4 Post Bullbar
