Old 12-14-2005, 07:48 PM   #1 (permalink)
zaffer
So, while I am driving my Samurai, I sometimes get a REALLY bad shaking in the steering wheel. I have checked the tie rods/wheel bearings and nothing seems loose. The left hub assembly is leaking, but doesn't seem loose. Everything else in the suspension seems tight. Any ideas?
zaffer is offline   Reply With Quote
Old 12-17-2005, 11:32 AM   #2 (permalink)
tom_riddle's Avatar
tom_riddle
hi zaffer. that used to be my problem with my jimny. when i reached 60kph, i experienced wiggling. but when i had the tires balanced, the wiggling is gone. hope this helps.
have a great day.
tom_riddle is offline   Reply With Quote
Old 12-20-2005, 07:37 AM   #3 (permalink)
Boris Ekner
Is there oil on the inner side of the tire? If so you most likely have a broken King Pin bearing.
If not check the front brake pads and calipers.
.. Boris
www.jimny.se
Boris Ekner is offline   Reply With Quote
Old 12-27-2005, 10:38 PM   #4 (permalink)
Hummerwannabe
You may want to adjust the play in your steering column, by going to the steering sector. There is a nut with a flat head screw in center - loosen nut to point you can tighten screw about i/2 turn - hold screw in place and tighten nut. See if that helps. If it helps a little, go back and re-adjust tighter. It's helped my '87.
Hummerwannabe is offline   Reply With Quote
Old 02-09-2006, 06:34 PM   #5 (permalink)
gargantula99
The problem is your Steering Dampner. It happened to me. I replaced it with a rancho one
gargantula99 is offline   Reply With Quote
