Originally Posted by Les.H
Still have problem with with intermittent fault reported earlier, Main Dealer has poo pooed idea of Cam&Crank sensors as the Inst pack lights dont flicker with these sensors faulty. Its getting worse now weather has warmed up, Main dealer cant help unless it breaks down completely. Is there help out there?
... well poo poo the dealer. If the car has to break down completely then, in my opinion the dealer is not doing his job. A (wildly) fluctuating tachometer when the problem is occurring is the key. This indicates that the ECU can't determine engine speed and thus can't get the timing and injection right. The engine will sputter and eventually die.
The crank/cam timing is the one input that your engine can't run without. It will run without O2, MAP, TP and IAT inputs but not crank/cam timing.
Ensure positive connection for the cam sensor (gray with a right angled connector at the top right of your engine). The crank sensor is tucked away such that you'd have to access it from below the car.
