Alternator mounting bolt sheered? - Suzuki Forums: Suzuki Forum Site
Old 01-30-2017, 08:15 AM   #1 (permalink)
johnhoneyman is on a distinguished road
Default Alternator mounting bolt sheered?
Hi all,
I was adjusting the alternator belt (Squealing) and when tightening the bolt on the adjuster to some form of mount it sheered off leaving the shaft still inside the mount.
Access is minimal to heli coil this. What does the alternator connect too.. Is it part of the engine ? or a mount that comes off?
johnhoneyman is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 09:48 AM   #2 (permalink)
Darrell.'s Avatar
If your referring to this bolt, it threads into the block casting. I don't know if the bolt protrudes out the back at all, with no load on the thread now, I'd expect it to not be very hard to turn if there's anything to grip on.
1987 SJ413 Rusty tin top, 2005 Grand Vitara 1600se.
Old 01-30-2017, 09:54 AM   #3 (permalink)
Darrell.'s Avatar
Another pic..
Old 01-30-2017, 12:42 PM   #4 (permalink)
That is the exact location... The bolt does go straight through and is now stuck inside since the nut sheered off whilst tightening
The belt is now squealing.. Any ideas guys and I appreciate the responses
Old 01-30-2017, 01:04 PM   #5 (permalink)
Darrell.'s Avatar
I can only suggest one of these drills and some extractor bits. Worse case it would need drilling completely out and a nut & bolt used.
Not the sort of drill most of us have though. I've got a 90 degree chuck jobbie to go on my drill but it's bigger than the one below.
Hopefully somebody's got a better idea.
Last edited by Darrell.; 01-30-2017 at 02:09 PM. Reason: I said one above, should have been one below!
Old 01-30-2017, 01:45 PM   #6 (permalink)
Access is limited in there... Will need to see what space there is.
Old 01-30-2017, 05:19 PM   #7 (permalink)
aquanaut20's Avatar
If the bolt is seized it is best not to attempt with easy out, it that break you will have a devil of a time (hardened steel).
I have had good results Mig welding a nut on the offending stud (even countersunk), the heat makes is loosen and the nut has purchase..
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 01-30-2017, 06:23 PM   #8 (permalink)
Darrell.'s Avatar
I've broken them off before at work, your proper stuffed if that happens
He did say it broke whist doing it up so I'm assuming its not seized, doesn't look a lot of room though. You never know, if the drill bites it may even wind out the back. Best of luck
Old 01-31-2017, 01:46 AM   #9 (permalink)
Yeah it wasn't seized ... I was adjusting the belt and whilst tightening, the nut sheered off leaving the stud inside.
Old 01-31-2017, 05:40 AM   #10 (permalink)
I found this:-
Erbauer Angled Chuck 10mm | Chucks & Keys | Screwfix.com
Perhaps this could help?
