» Sponsor Links
»Garage Storage and Cabinets
Old 01-19-2007, 06:46 AM   #1 (permalink)
Kate is on a distinguished road
Default cd player code problems!
hey, i have just recently had a new battery put into my 2001 ignis and my cd player no longer works. its says to put in a code. the code to my cd player includes the number 0 and i am unsure where this button is on the cd player... if anyone could help i would really appreciate it! thanks alot!
Kate is offline   Reply With Quote
Old 02-22-2008, 01:41 AM   #2 (permalink)
RIc
RIc is on a distinguished road
Default Solution
Hey, I came across this problem too.. and hack... i found this thread without a solution.
Yet, I'm here to provide this solution:
SIMPLE VERSION for u, Kate:
1. Turn on the CD player, and u see CODE
2. Press and hold DISP for 2 sec
3. Press 1 ten times, then u will know what u are going to do with the code.
And u can enter 0~9 in such way, trust me. I have a code with 9.
(make sure u watch the screen while doing it... press 2 several times too.. if u still don't get it. )
LONG VERSION:
It's from the CD player manual - "CD Tuner Operating Instruction" p.2.
(I got a ugly printed one)
Security Coding
This Audio unit is protected by an electronic security system, which renders it inoperative if it is removed from the vechicle or the battery is disconnected. The unit will not operate again until the correct four digit Security Code is entered.
To enter the Security Code: (I know u are still reading this, Kate.. )
1. Turn the ignition to the accessory position.
2. Press the PWR button to turn the unit on.
3. Press the DISP button for 2 seconds to start Security Code input.
4. The Display indicates the four code digits and starts from 0000.
5. The Security Code digits can be incremented by pressing the Presest Memory buttons "1(3) 2(4) 3(5) 4(6)" respectively at 1 increment per each press of a button.
(don't think anyone can understand this junk.
In English, press 1 to change the 1st digit, press again til u got the number. Press 2 to change the 2nd digit, and so forth)
6. When all four numbers visible in the Display are correct, press the DISP again.
If the security Code entered matches thhhheeeeee faaaaccccctttttoooorrrryyyyyyy ......... ...... ....... zzzzzzzzz
(sorry, i felt slept... OF COURSE ITS DONE WHEN IT MATCHED..... )
If the security code is incorrect....... THE UNIT WILL BE SELF-DESTROYED IN 5 SECONDS. RUN, boy, RUN !!! 5 4 3 2 1 ...
If u are doing this with your seat-belt on, the air bag may activate to protect your face, not your body nor leg.
Ehhh.. You know it won't do that ... do u ?
It just said u have to wait for 1 minutes to start again....
If u put it wrong again, 2 minutes penalty, again, 3 minutes.. until 16 minutes, u got 16 minutes wait every time u did it wrong.
(kinda stupid, but Honest, that's what it said.)
By the way... the possibility of enter it wrong for 16 times...
I wanna met u in person, remember to bring your wallet and cheques along (don't think u still have any ATM cards... )
RIc is offline   Reply With Quote
Old 02-22-2008, 02:15 AM   #3 (permalink)
RIc
Oh I forgot... To get the maximum performance, pls follow this:
1. Download the Mission Impossible theme into your ipod.
2. Bring a small torch. Wear something tight.
3. Drive your IGNIS into dark corner or crack that lightbulb in your garage.
4. Jump in to the back seat and wear seatbelt for maximum restraint.
5. Put on your ipod, play the theme, and start DE-CODE.
6. I hope u can finish your extreme task and jump back to driver seat, step on the pedal before the theme ended.
7. MISSION ACCOMPLISHED.
8. Practise again if u want to pursue an career in the industry. (whatever it is..)
9. And i finally discover it's a year long topic before SOMEONE really answer it... GOOD JOB PAL... bad for u KATE, your car running without music for a whole year...
