Suzuki-Forums.com is the premier Suzuki forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-27-2010, 06:39 AM   #1 (permalink)
demers669 is on a distinguished road
Default 2007 Forenza a/c recharge question
I am trying to locate the low pressure side valve to recharge the system. I found a tube near the passenger side of the firewall with a green cap. Is this the low side? Thanks in advance
demers669 is offline   Reply With Quote
Old 07-27-2010, 08:50 AM   #2 (permalink)
onlyhuman is on a distinguished road
no, thats the high pressure side and has the letter H imprinted on the cap. The low pressure valve is even closer to the firewall, between the throttle body and the fender, below the air intake hose. It has a black cap.
onlyhuman is offline   Reply With Quote
Old 07-29-2010, 01:02 PM   #3 (permalink)
Dj Low Proz's Avatar
Gallery: 22
Dj Low Proz is on a distinguished road
how often are you suppost or need to recharge the a/c i have a 07 reno and the air doesnt seem to get cold enough for me even on max it would prob help if i tint the windows but in Va the tint laws are so light id have to go with with 50% on fronts and 35% on rears id rather do 20% all the way around but would risk getting tickets left and right
What I done so far
Pioneer Avic-D3, Fronts Kicker Ks Components 602, Rears Kicker Ks Components 502, Eclipse EA4200 4 Channel Amp, Bass Kicker Cvx 15"(SPL) and RE Audio Sx 10" (Daily Driver), Kicker Zx1000.1, Kicker 0/1 gauge amp kit with RCAs, DDM Tuning 4500k Hids, Hid Tag Lights, NGK plugs and Wire Set, BMS CAI In Black, The Big 3 Upgrade in 4gauge wire
http://www.myspace.com/djlowproz
http://www.cardomain.com/ride/2643224
Dj Low Proz is offline   Reply With Quote
Old 07-29-2010, 04:57 PM   #4 (permalink)
you shouldn't really need to recharge a 07 unless there is a leak.. but at the same time.. keep in mind that... the ac sucks quite a bit in these cars.. there is a thread about "ac not cold enough".. its just the way it is..
from walmart.. you might want to invest in a can of refrigerant that comes with a gauge.. plug that gauge in and read the value.. chances are it has the correct amount. last year, I put a little extra.. taking it to the top of the acceptable pressure range.. not more.. didnt really make a difference.. this year.. i wanted to do the same.. but over charged it by mistake and then had to pay a shop to hook up the ac system to the machine to get it corrected.
one suggestion is to have your "recycle" on.. it helps a lot.. the cooler the inside gets, the colder air it blows.
Old 07-30-2010, 09:56 AM   #5 (permalink)
Gallery: 22
Yeah i notice that in the past i rarely used my ac but since this summer has been so warm i have been using the ac alot lately. I also notice that the A/C robs the performace of the car.
yes I always use it on recycle after the a/c starts to feel cooler so it does blow harder at least
What I done so far
Old 07-31-2010, 02:53 PM   #6 (permalink)
I figured the cap with the H was the high side. Thank you for the reply. The A/C does work a bit and hoping the recharge kit works & I do not have a leak
Old 08-02-2010, 09:48 PM   #7 (permalink)
Default Success
Found the low side and added the refrigerant to the system. Will have to see if it stays or if there is a leak. A/C working well!! Thanks to all that replied.
