Old 10-01-2009, 05:48 PM   #1 (permalink)
Schmeg's Avatar
Schmeg is on a distinguished road
Default High Beams Work, but NO LOW BEAMS!! Please help!!
I need some help you guys. For a while, my high beams wouldn't work unless i held the switch back, now they work normally. Unfortunately, my low beams both quit working at the same time. I know it has to be a problem with the switch in the steering column because all of my fuses are intact and unbroken and my bulbs are still intact. Please help. I need to know how to get that big plastic cover off of the steering column to get to the headlight switch and wiring. For a bonus point, can anyone describe what this switch's wiring looks like under the steering column. Thanks for the help!!
2004 Suzuki Forenza - Blue - Platinum Jewel 15" Rims
Schmeg is offline   Reply With Quote
Old 10-01-2009, 08:07 PM   #2 (permalink)
Gallery: 11
it sounds like you might need to take the car in for the lighting recall.
Old 10-05-2009, 06:46 PM   #3 (permalink)
If you have not had the DRL recall then get that done but sounds like a possible open/shorting issue under the left front fender.
Old 11-14-2009, 08:05 AM   #4 (permalink)
cbjr61 is on a distinguished road
had same problem its the wiring harness behind spedometer it was recall problem where they repair the 3 purple wires . but the others wirs in the same plug heat up as well and loose contact samething easy to fix noy under warranty thre are other posts that tell you exactly step by step to take cluster apart took me 15 minutes to fix car dealer wanted 100 just to look real ripoff
cbjr61 is offline   Reply With Quote
