They are special order items but I need to order another one for myself and someone else so if anyone else is intrested you'll save money if you jump on it now.
Add a lightweight flywheel for $100 more with the purchase of a clutch kit. Lemme know if your intrested asap...it will require a 50% non-refundable deposit as they are special order only. The clutch kits have different styles for weather you choose to use the stock flywheel or a lightweight flywheel that I sell. So you can't get a clutch kit for your stock flywheel now and change the flywheel to a lightweight one as they use different styles so choose now. Also you can only use a lightweight flywheel if you get a clutch kit that has a pressure plate with it...aka if you get just a 3 puck clutch and use the stock pressure plate then a lightweight flywheel will NOT work.
Also the flywheels are used, but I do check if they are in good working order. If you guys have to know what make/model they are from I'll tell you but it won't do much good as I've pretty much bought them all! lol. The flywheel will have to be resurfaced...I was gonna do it myself but whoever installs your clutch kit and flywheel should be able to resurface it there anyways.
-$xxx (still getting a qoute) for 3 puck ceramic clutch w/ your current stock pressure plate (For up to 210bhp)
-$405 for 3 puck ceramic clutch w/ your choice of pressure plate (For up to 210bhp)
-$445 for 4 puck double spring ceramic clutch + 750lbs pressure plate (For 220-270bhp)
-$525 for 6 puck double spring ceramic clutch + 1200lbs dual finger pressure plate (For 280-390bhp)
-$100 for a lightweight flywheel with the purchase of any clutch kit (note it will only work with one of my aftermarket pressure plates).
Woot, I'll take one. 220-270. I probablywoant need all that, but better to have grouth room then no.
Throw in the flywheel also!
I'm a sucker for my car. I guess its true,with no girl, you marry your car
Awesome! I'll let you know exactly how much it costs. I only got a qoute for other kits so it'll take an extra day or so!
can they get the flywheel separate? If so let me know a price if possible.
"Oversteer is when the passenger is scared; understeer is when the driver is scared!!"
"Thats why you can't hit 120. Get a set of better tires with a high enough speed rating and you should hit it." -Jurupa
Exactly right my friend, however I would be going with a custom clutch if I do go through with the flywheel
