Too high idling - Suzuki Forums: Suzuki Forum Site
Old 10-24-2010, 10:15 AM   #1 (permalink)
Bondekarlen is on a distinguished road
Default Too high idling
Hi all
Hope some one can give me a clue.
I have just mounted a new(second hand engine) in my daugthers Baleno 1,6 wagon.
It starts and run perfectly, but the idling is too high.
When it gets warmed up its about 1900-2000 rpm.
I have checked the trottle stop and all connectors at the injecting system and all seems fine.
Just tried to spray some diesel start at the complete system to see if runs faster, but no.!
Any ideas are very welcome.
Greetings from Denmark
Jan
Bondekarlen is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 07:05 PM   #2 (permalink)
Eyal's Avatar
Eyal is on a distinguished road
maybe it pulling air from someware
eyal
israel
Eyal is offline   Reply With Quote Quick reply to this message
Old 11-29-2010, 12:51 PM   #3 (permalink)
cawalther is on a distinguished road
you should run by your local auto parts store or shop and ask them to scan your OBDII and see if you get any codes.
I'm thinking you might get a P0507 code for idle air control issues. The manual also mentions the EVAP Control System with high idle, but not sure.
I got this from autozone too:
Trouble Code: P0507
Idle Speed Control System Higher Than Expected
Possible Causes:
IAC valve control circuit is open (intermittent fault)
IAC valve power circuit is open (intermittent fault)
IAC valve ground circuit is open (intermittent fault)
Throttle plate is carbon fouled (it may need to be cleaned)
PCM has failed
cawalther is offline   Reply With Quote Quick reply to this message
