fog lights
I don't know if this info will help you, here in the colonies we have the Esteem and they only have front fog lights, in reading your letter, i see that your Baleno's have rear fog lights, must get foggier than snail snot !
Power is supplied to the fog lights in this fashion :
A. Ground or Earth Ground is supplied to the Negative input to the fog light, Positive is supplied to both of the fog lights via a BLU/RED wire from a relay, this relay receives its source voltage from a 25 amp fused connection.
The operating voltage for this relay receives its source voltage from the Fog Light switch via a LT GRN/RED wire.
In the fog light switch, there is an indicator bulb, the indicator bulb is lit, when the fog light switch is pressed in the on position, the indicator bulb receives its source voltage via a BLU/BLK wire directly from the RHS headlight, this wire is fused at 15 amps.
The Fog Light switch receives operating voltage from fog light relay # 2 via a ORN wire.
Voltage is supplied to fog light relay # 2 via a BLU wire from the Day Time Running Lamp Controller (DRL).
Operating voltage for fog light relay # 2 is via a RED/WHT wire from the RHS and LHS headlights.
i hope this helps 1998 - 2001 esteem wiring manual
