Old 08-06-2009, 08:32 PM   #1 (permalink)
trigun7469 is on a distinguished road
Default Engine Code Evap has big leak
When ever I drive on the highway for over a hour a check engine light comes on says that I have a big evap leak, I clear the code and then I changed the Evap hoses, but it still comes on, what else should I be looking for? MPG don't seem to be effected by the problem, and street driving does not trigger it. Thanks
trigun7469 is offline   Reply With Quote
Old 08-06-2009, 10:11 PM   #2 (permalink)
likely the evap vent valve stuck open.
2008 suzuki SX4 sport sedan 5spd FWD
2006 suzuki boulevard C50 SE
lumpylarry is offline   Reply With Quote
Old 08-06-2009, 11:20 PM   #3 (permalink)
jim_naisium is on a distinguished road
What is the error that it is giving you?
jim_naisium is offline   Reply With Quote
Old 08-07-2009, 12:17 AM   #4 (permalink)
Isuzuzuki man's Avatar
Try a new gas cap.
For sale; CV boot kits for 2002 Esteem automatic.
2002 Nissan Quest GLE
1991 Geo Storm GSi
2002 wagon SOLD
2002Esteem 4 dr SOLD
my first Esteem RIP
1992 Impulse
Old 08-07-2009, 05:34 PM   #5 (permalink)
How would I be able to check that?
unfortunately I forgot to write down the code next time it happens all post it.
Old 08-07-2009, 06:41 PM   #6 (permalink)
remove the valve, depending on which model you have, it may be under near the tank or in the engine bay if thats where the canister is.
with the valve out of the car, air should flow freely between the 2 ports.
using jumper wires, apply 12v across the pins of the valve.(a 9v battery will also work)
you should hear a solid "click" and air should no longer pass through the valve.
if yours is the one near the tank, you will be able to see the plunger move inside the valve when voltage is applied.
you can also measure resistance, should be 25-30 ohms
if there is no click and air can still pass through when voltage is applied, replace the valve.
hope this helps
Old 08-08-2009, 03:53 PM   #7 (permalink)
hope this helps
Is that off of a 2001?
The engine code is P0455
Old 08-08-2009, 05:06 PM   #8 (permalink)
1.8 or 1.6?
Old 08-08-2009, 07:05 PM   #9 (permalink)
1.8 or 1.6?
it's the 1.8
Old 08-08-2009, 11:29 PM   #10 (permalink)
yup, thats the one. its located right behind the fuel tank on the cross member.
