Old 07-01-2009, 03:07 AM   #1 (permalink)
Ahmed Rashid's Avatar
Ahmed Rashid is on a distinguished road
Default Tappet adjustment of baleno 1.3
Can any body explain me easiest way to adjust the tappets of baleno 1.3 modle 1999 ?
Ahmed Rashid is offline   Reply With Quote
Old 07-04-2009, 03:06 AM   #2 (permalink)
any body? i am still waiting for reply
Old 07-05-2009, 01:11 AM   #3 (permalink)
Isuzuzuki man's Avatar
There is no easy or hard way, only one way. First pull the VC, you can do this one of two ways, if you have a book, it will tell you which tappets are closed at a certain time, I just rolled the engine around with a ratchet on the crank bolt with the plugs out until the valve was closed. Start with the front and work back or vice versa, roll the engine until the cam lobe is on the base circle for the tappet you are adjusting, (when the lobe points away from the tappet), check and adjust the clearance as needed using thickness gauges. Repeat for the other tappets.
For sale; CV boot kits for 2002 Esteem automatic.
2002 Nissan Quest GLE
1991 Geo Storm GSi
2002 wagon SOLD
2002Esteem 4 dr SOLD
my first Esteem RIP
1992 Impulse
Isuzuzuki man is online now   Reply With Quote
Old 07-05-2009, 09:27 AM   #4 (permalink)
to adjust, loosen the 10mm nut and turn the adjuster screw with a slot screwdriver.
i find it easier to measure right at the cam instead of between the lifter and valve..
hope this helps..
2008 suzuki SX4 sport sedan 5spd FWD
2006 suzuki boulevard C50 SE
lumpylarry is offline   Reply With Quote
Old 07-06-2009, 02:46 AM   #5 (permalink)
A lot of thanks both of you@Isuzuzki man & @lumpylarry.
@lumpylarry, is it authentic way to check the valve clearance by inserting filler gauge inbetween cam and rocker arm for 16 valve engine ?
Old 07-10-2009, 06:22 AM   #6 (permalink)
Can we get accurate valve clearance by inserting the feeler gauge inbetween cam and rocker arm instead of valve stem & adjustment screw ?
any body,pl reply!
Old 07-10-2009, 11:56 AM   #7 (permalink)
thats where alldata says to measure it.. ive never had any broblems doing it that way..
Old 07-14-2009, 11:40 PM   #8 (permalink)
Thank you vary much lumpylarry for removing my confusion,and by following your advice i have adjusted tappet easily.
