Proper Brake Bleeding sequence?? - Suzuki Forums: Suzuki Forum Site
Old 05-20-2009, 07:07 AM   #1 (permalink)
Patrick t is on a distinguished road
Default Proper Brake Bleeding sequence??
Hi ALL!
I have a 1998 Esteem Wagon GLX 1.6L (LEFT hand steering, just like the U.S.). Is the Brake system of the Esteem the DIAGONAL split system ("X") or the old Front-Back split system?
The reason i asked is that i plan on changing brake fluid and bleeding the brake system as well. So do i start bleeding from the brake farthest from the Master Cylinder and finally to the brake closest to the M/C, thus in order: REAR Right-REAR Left-FRONT Right-FRONT Left?
OR, if its a DIAGONAL split system, do i do the ff in order: REAR Right-FRONT Left-REAR Left-FRONT Right. What does SUZUKI recommend? THANK YOU!
Patrick
Patrick t is offline   Reply With Quote Quick reply to this message
Old 05-20-2009, 10:05 PM   #2 (permalink)
Isuzuzuki man's Avatar
I don't know what Suzuki recommends but I did mine farthest to nearest, I don't think its that critical.
For sale; CV boot kits for 2002 Esteem automatic.
2002 Nissan Quest GLE
1991 Geo Storm GSi
2002 wagon SOLD
2002Esteem 4 dr SOLD
my first Esteem RIP
1992 Impulse
Isuzuzuki man is offline   Reply With Quote Quick reply to this message
Old 05-22-2009, 10:58 PM   #3 (permalink)
silver is on a distinguished road
It does not really matter that much, the correct sequence will use the least amount of fluid that's all.
silver is offline   Reply With Quote Quick reply to this message
Old 05-22-2009, 11:22 PM   #4 (permalink)
I just thought i`d do what was "best". Apparently it doesnt matter much. THANKS guys!
patrick
Old 05-23-2009, 11:54 AM   #5 (permalink)
RebelPC` is on a distinguished road
patrick
It does matter.......start at the farthest wheel from the master cylinder like Isuzu said. Of course if you didnt let any out it doesnt matter unless your replacing a wheel cylinder or a caliper. You should be able to do a brake job without letting any air into the system. Also unless your brake fluid is contaminated(like you have no cap on your master cylinder) you should never have to "replace" your brake fluid. Replacing the brake fluid is NOT going to make your car stop any better.
RebelPC` is offline   Reply With Quote Quick reply to this message
Old 05-23-2009, 11:11 PM   #6 (permalink)
REBELPC- I replace my brake fluid once a year because its just a DOT3, so its hygroscopic, and 85% HUMIDITY is common in this here tropics!
I figure there isnt any harm in replacing most of the brake fluid by just bleeding the old fluid away so i get the assurance (call me obsessive compulsive if you will) of an air free brake system. I sometimes think about emptying out the Master cylinder not just from the reservoir but using compressed air to push out the little bit of fluid left inside the M/C out where the hard brake lines attach to the M/C. But then i dont know how easy or hard it is to bleed the M/C itself (since its already 11 yrs old).
I normally use the conventional bleeding sequence on my other even much older car but just thought i`d follow factory recommendations for whatever its worth(?)
Old 05-26-2009, 12:13 AM   #7 (permalink)
LOL you do what you want, I lived in South Florida that IS the tropics and now I live in the Pacific Northwest rain 9 months a year.......Ive never worried about it......
Old 05-27-2009, 08:31 AM   #8 (permalink)
Brake fluid absorbs moisture, its very hygroscopic, moisture rusts the insides of the brake system, it can turn to steam at the wheels under braking, that in turn causes mushy braking. Heat also breaks down the fluid over time.
I have seen it many times, the fluid will be the dirtiest at the wheels were you can't see it. Bleed it into a glass jar, you will see.
Brake fluid id like any other fluid, it wears out.
Patrick, DO NOT use compressed air in the brakes system, you will only make it worse, just bleed it until the fluid looks clean at the wheels.
1991 Geo Storm GSi
2002 wagon SOLD
my first Esteem RIP
1992 Impulse
Old 05-27-2009, 11:00 PM   #9 (permalink)
ISUZUZUKI MAN- I do in fact use a clear jar when bleeding to check for air bubbles and fluid condition. Years ago i had used compressed air on what was then a 25 year old car and got problems bleeding the m/c and had to bring it to a shop for bench bleeding (especially as the seals were that OLD!).
So i was hoping the esteem m/c would be easier to bleed (?) as it is a newer car. I`l just take your advice not to do the compressed air bit. THANK YOU! patrick
