» Sponsor Links
»Garage Storage and Cabinets
Old 09-15-2008, 12:40 PM   #1 (permalink)
Fab
Fab is on a distinguished road
Default Esteem Hard Starting & Stalling
1999 Esteem Wagon GL, 1.6l, 5spd manual
Hard to start.... takes several attempts to start (worse when hot). Then runs well while driven, but when idling it will stall. Have kept the A/C on (slightly increases idle rpm) and has helped a bit. Any ideas/thought? Air filter has been cleaned, plugs replaced, oil changes as required.... Maybe fuel filter???
A while back, the check engine light was always on. ODB reader pointed to O2 sensor.... I replaced the sensor and reset the light. Now the check engine light is gone but still have starting/stalling problems.
Anyone have/had these problems? Appreciate your feedback.
Thanks.
Fab is offline   Reply With Quote
Old 09-16-2008, 12:17 AM   #2 (permalink)
Isuzuzuki man's Avatar
Replace the fuel filter, and then maybe look into getting the injectors cleaned.
Edit; if it has a replaceable FF, mine does not.
2002 Suzuki Esteem Wagon
2002 Suzuki Esteem Sedan
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 10-26-2008, 08:54 PM   #3 (permalink)
RebelPC` is on a distinguished road
Had some problems like that on my 1998 Esteem 1.6 The IAC(Idle Air Control) motor gets all gunked up with exuast carbon and needs to be cleaned. It will get stuck from time to time causing symptoms like you speak of. This is generally done by removing the Throttle Body. DO NOT REMOVE THE IAC SPECIAL SCREWS!! OR YOU CAN DAMAGE THE IAC!! Youll know them when you see them they resemble Torx........Use the other ones. Spray some good carb cleaner and use a q-tip and clean the carbon out of the passages. Reassemble and this should take care of your dying problem.
RebelPC` is offline   Reply With Quote
