der MAP baro
you are correct, we have examined every wire to every sensor, as you know some have a MAF hidden in TB. (not on this one)
the OBD2 scan tool (elm based) is showing MAF, but we think it is
calculated air flow and not measured air flow.
we have a raw data logger to prove that and may later, when we find the drain hole in this swamp.
some air leaks in to induction,causing IAC to rail.
thanks for helping.
