» Sponsor Links
»Garage Storage and Cabinets
Old 08-27-2008, 08:24 PM   #1 (permalink)
silver is on a distinguished road
Default oil pan gasket
oil is leaking out from my 1998 esteem oil pan.
Have anyone here done a gasket replacment and can give a a couple of pointers ?
silver is offline   Reply With Quote
Old 08-27-2008, 10:03 PM   #2 (permalink)
Isuzuzuki man's Avatar
Most foreign engines don't have a gasket but rather gasket sealer, they offer a gasket for this one however, I chose not to use one, I've had better luck with ultra silicone, never had a leak with it yet and it doesn't shrink like gaskets.
I know you have to remove the Xmember under the engine and exhaust downpipe.
If you don't have access to a parts washer get a can of gunk engine cleaner and a parts brush, completely liquefy all the gunk inside and out of the pan, it will take repeated spraying and brushing, spray off with water and dry.
The gunk will also soften any sealant on there, use a stiff bristle brush or scraper to get it off, you can do this before you hose it off. Use a razor blade on the engine surface. Clean the engine surface with brake clean. You may want to inspect and/or clean the oil pickup tube at this point. Reseal.
2002 Suzuki Esteem Wagon
2002 Suzuki Esteem Sedan
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 08-27-2008, 10:13 PM   #3 (permalink)
Thanks for the reply, Isuzuzuki man.
Is there anyway to seal it on the outside without taking the pan off ?
Old 08-28-2008, 09:39 PM   #4 (permalink)
Nope, unfortunately not.
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 08-29-2008, 07:36 PM   #5 (permalink)
Brit101 is on a distinguished road
My mechanic changed mine, and he used black silicone I believe, it was hard to find a gasket. At first he was going to remove the exhaust pipe at the join, three studs and a gasket. However he just removed the exhaust manifold and lowered it. That way there was no need to buy all the bits, and it bolted up with no need for a new gasket, just used the old one. So far no problem and it was done this February.
Brit101 is offline   Reply With Quote
Old 08-30-2008, 05:29 PM   #6 (permalink)
One thing I failed to mention, let the silicone dry at least 8 hrs before adding oil.
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
