» Sponsor Links
»Garage Storage and Cabinets
Old 08-21-2008, 11:26 AM   #1 (permalink)
mosquito122 is on a distinguished road
Default Suzuki Esteem Wagon
My daughter broke key off in ignition switch! Help! How do you get the ignition switch off?
mosquito122 is offline   Reply With Quote
Old 08-21-2008, 12:21 PM   #2 (permalink)
Easier to get the old key out using small dental style pick and treezers.
SuzukiDon is offline   Reply With Quote
Old 08-22-2008, 09:30 AM   #3 (permalink)
Tried that, didn't work! Broken end is to short and bent it won't come out
Old 08-22-2008, 10:16 AM   #4 (permalink)
Remove the plastic covers around the column and should be obvious how to access. The lock assembly is replaced not just the key cylinder. You have 2 security bolts ( bolts with no heads) that hold the clamp around the column. You can get these out with a punch or cut a slot in them with a Dremel tool so as to use a screwdriver. New lock assembly has new break-a-way bolts.
Old 08-22-2008, 10:43 AM   #5 (permalink)
Thanks, will try that, we do have the steering wheel off and all plastic covers so just need to find these bolts.
