Most Balenos seem to have the OBD2 connector with only pins 16, 5 and 9 connected - that is the Suzuki proprietary interface. I have a 2000 1.6 Baleno engine here but I haven't tried to hack the interface yet. I'm missing the wiring from under the dashboard. My project for this winter is to hack the ECU. I'm hoping the OBD interface is the same as that fitted to other Suzuki models.
http://www.suzuki-forums.com/suzuki-...nterfaces.html
A guy in India has already tried this protocol without success but it may be a problem with his interface or software. If it doesn't work then I'm pretty confident that I can pull the code from the ECU and then it should be simple to work out the protocol. The processor in the Baleno ECU is a common processor unlike the proprietary item in the Vitara/Sidekick ECUs.
