» Sponsor Links
»Garage Storage and Cabinets
Old 05-11-2008, 11:03 PM   #1 (permalink)
Jay-Impala-man is on a distinguished road
Default Engine knock?
My 98' Esteem has a loud knocking when it is cold outside and goes away after the motor gets warm. What could it be? I have over 103,000 miles on it. I keep everything changed on it. Please help. Jay-Impala-man kkjc805@netscape.com
Jay-Impala-man is offline   Reply With Quote
Old 05-12-2008, 12:21 AM   #2 (permalink)
Isuzuzuki is on a distinguished road
Sounds like a lifter is sticking.
Git Er Dun!
92 Isuzu Impulse XS, 5 sp, DOHC 16V, 1.8L 140HP rare as frog hair Handling by Lotus
2002 Suzuki Esteem, 5 sp, GL
2002 Suzuki Esteem Wagon, GLX
92 Impulse
1.8
Isuzuzuki is offline   Reply With Quote
Old 09-07-2008, 10:46 PM   #3 (permalink)
maverick214 is on a distinguished road
Did you find out what this is?
My 2001 with 124k miles has a loud knock that goes away after warm.
Also, looks like you have to adjust the valves on the 1.6l engine, anyone know how to do this?
Thanks!
maverick214 is offline   Reply With Quote
Old 09-08-2008, 11:32 AM   #4 (permalink)
Isuzuzuki man's Avatar
A solid lifter, one that is adjustable is not the type that generally can stick and make loud noises. A hydraulic lifter can do that, especially in cold temps when the oil is thick.
Adjusting the solids is easy; start with any cylinder, number one is good, rotate the engine until all the valves are closed (the cam follower is on the base circle and not the lobe), this occurs at TDC of the power stroke, using a feeler gauge of the specified thickness (see manual) check the gap, it should be a slight drag, if not adjust it. It doesn't have to be perfect, the manual specifies the range, plus or minus .001" should be fine. Rotate each cylinder to TDC of the power stroke and repeat. Note the EX and In valves have different gaps.
2002 Suzuki Esteem Sedan
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 10-13-2008, 02:42 AM   #5 (permalink)
joseph2008 is on a distinguished road
Engine Knocking in spark-ignition internal combustion engines occurs when combustion of the air/fuel mixture in the cylinder starts off correctly in response to ignition by the spark plug, but one or more pockets of air/fuel mixture explode outside the envelope of the normal combustion front. The fuel-air charge is meant to be ignited by the spark plug only, and at a precise time in the piston's stroke cycle.
__________________________________________________ ______________
LA Flowers low rate loans penedes ringback tones
joseph2008 is offline   Reply With Quote
Old 10-13-2008, 11:32 PM   #6 (permalink)
But knocking is something that happens under hot load conditions. This sounds more like something in the engine that is loose, as the engine warms up the parts expand and take up the space, thus any looseness may become inaudible.
2002 wagon
2002Esteem 4 dr
my first Esteem RIP
1992 Impulse
Old 10-14-2008, 08:06 PM   #7 (permalink)
muthu is on a distinguished road
Default RE: Engine knock?
Knocking in an engine is not good and it may need to be rebuilt by a professional so I would not ride any more until a motorcycle mechanic looks it over. If your bike is a 2 stroke engine the engine will need to be rebuilt every 50 or so hrs but depending on hard it is ridden, etc.
Muthu
...::: Sreevysh Corp :::...
muthu is offline   Reply With Quote
Old 10-26-2008, 08:29 PM   #8 (permalink)
RebelPC` is on a distinguished road
Like any engine with 100,000+ miles things get a bit worn.......try an additive.....I swear by Lucas Oil Stabilizer........it will keep a nice coating on the worn parts and help when the engine starts cold.....should help quiet it down consideralbly..........
RebelPC` is offline   Reply With Quote
