Old 04-03-2008, 12:14 AM   #1 (permalink)
wingover is on a distinguished road
Default 2000 esteem transmission
Hi,
Just got an Esteem 2000 1.6L engine with 5 speed manual trans.
The trans is making a loud noise ( like a broken tooth.. Klank, klank) in first gear and less noise in all the rest.
I would like to replace the tranny and not fix it.
Does the Suzuki Swift 1.3L engine have the same tranny? or the Geo metro? or any other model?
There aren't many Esteem's here.
Thanks,
Mike
wingover is offline   Reply With Quote
Old 04-03-2008, 12:28 AM   #2 (permalink)
jim_naisium is on a distinguished road
Hi,
Is the transmission oil level up where it should be? If you don't know where the filler plug is go here: http://home.comcast.net/~lj_robins/p..._oil_plugs.jpg
That clang may be something in your clutch assembly that is broken, like maybe one of the fins in the pressure plate, or the throw out bearing. On that note it may not be the transmission at all and could be that your CV-Joints have gone bad.
I'm not sure what would be compatible with your car, call the junk yards they can tell you what other cars have a transmission that will work.
jim_naisium is offline   Reply With Quote
Old 04-03-2008, 01:17 AM   #3 (permalink)
Thanks for your reply.
When I press on the clutch the noise goes away. The sound also changes frequency with the different gears and in fifth you can't hear much.
Still would like to know if the Swift and Geo tranny would fit.
