Old 03-29-2008, 06:20 AM   #1 (permalink)
picko is on a distinguished road
Default 01 balino pop and no gears.. help
hi i done a left outter cv boot on a 01 balino 5sp man, because every time u turned right the left cv sounded to clack , but the cv end made no difference and the car was driven an hour to home and then the car was backed up about 3 meters and pop. now no gears at all no ford and no reverse, but the gears still select but motor dose not turn box. if any one seen this before pls piont me in the right direction, clutch ?? i dont know thanks
picko is offline   Reply With Quote
Old 03-29-2008, 11:53 PM   #2 (permalink)
jim_naisium is on a distinguished road
Sounds like your CV-joint finally broke, when they start clattering they need to be replaced. With slip differentials the tire with the least resistance spins, watch the drive axle while someone else gives it gas, if you see the axle spinning but the tire isn't moving the CV-joint is most likely broke.
jim_naisium is offline   Reply With Quote
