Where is the 2nd fuse box? - Suzuki Forums: Suzuki Forum Site
Old 12-17-2007, 10:36 PM   #1 (permalink)
Laf
Laf is on a distinguished road
Default Where is the 2nd fuse box?
Hey.
I'm trying to locate the radio fuse and cannot find the box. There is one on the driver's side under the hood and according to the manual, there should be another under the dash driver's side. But i can't find it!
The reason i'm looking in the first place is this: when everything is shut down, the radio display is still lit. No digits appearing, but the whole display glows a bit. Hadn't noticed until a few months back. Now, i had to change the alternator about a month ago, then the battery died a week later and the last few days, it has trouble starting, even with the new battery. Nights are getting colder (-18 C), but i never had this trouble before, even at -30 C. Could this radio display thing be draining the battery?
Thanks for any help.
Suzuki Esteem 2000 1.6 L
Laf is offline   Reply With Quote Quick reply to this message
Old 12-18-2007, 09:47 AM   #2 (permalink)
thejerkson is on a distinguished road
Under the dash on the drivers side close to the side of the car. Ya it's a pain.
thejerkson is offline   Reply With Quote Quick reply to this message
Old 12-18-2007, 10:41 AM   #3 (permalink)
Laf
Default Thanks
I'll check again...
Any idea why the radio display seems to glow?
Old 12-18-2007, 10:58 AM   #4 (permalink)
Ya, it's a little black box. Should be able to find it with a flashlight. As far as the display goes I don't really know. I know there is always power to the radio to keep the clock going. Perhaps if the radio isn't stock it's using that power supply for the display as well? Best to take the fuse out though and see if the problems continue. Then maybe take the radio out and test the cables with a voltmeter while the car is turned off.
Old 02-03-2008, 03:25 PM   #5 (permalink)
jorge0608 is on a distinguished road
Like everyone said, the fuse box is located under the driver side dash. It's hidden way in the right rear part of the dash. you will need a flashlight in order to see it. If the fuse box has the cover on, you will need to remove the cover. Use a flat head screw driver for this.
It sounds like you have a short somewhere. Did you get an aftermarker stereo installed? If so, recheck all of your wires.
Cheers!
jorge0608 is offline   Reply With Quote Quick reply to this message
Old 02-04-2008, 01:02 AM   #6 (permalink)
jim_naisium is on a distinguished road
To find the other fuse box (in US cars) get on your back and slide underneath the steering column and look straight up on the left hand side of the steering shaft clear up at the top of everything you will see it there, and as someone else said you will need a flashlight.
The reason the back light is coming on is because that is on a separate circuit from the power that makes the radio functional, a majority of the lights on the dash are all run from the head light switch.
jim_naisium is offline   Reply With Quote Quick reply to this message
